This command configures the restart helper router to terminate OSPFv3 graceful restart when received LSAs would affect the restarting router. This occurs when the restart helper receives an LSA that will be flooded to the restarting router or when there is a changed LSA on the restarting router's retransmission list when graceful restart is initiated.
| virtual-link | OSPFv3 virtual link. |
| routerid | OSPFv3 router ID. |
| router-identifier | Router ID of neighbor OSPFv3 router. |
| area | OSPFv3 area. |
| area-identifier | Transit area ID of virtual link. |
| restart-helper-lsa-check | Terminates graceful restart helper mode when there is a change to an LSA (default is enabled). |
Enabled.
This command was first available in ExtremeXOS 21.1.
